Engine Walker Electrical Problem
avilleace
I have a 2005 Walker MT20. It would not start, the battery was weak, I replaced it and now it will start fine but when I push lever for forward travel the engine starts to shut down. I can pull back and it will keep running. It is like a kill switch is enganged when I try to go forward. It will travel in reverse fine.
I disconnected my seat kill switch, but did not make any difference. I have tried it both ways. Also the voltmeter is over in the red as if it is overcharging.
Any ideas?
Thank.s
avilleace
Any ideas?
Thank.s
What about replacing the neutral safety switch? How can I check that? Anyone??
