Walk Behind Mower Transmission (4 Speed Peerless)
Kodie's Lawn Service
I wondering if you have to fill the inside with grease???? If so how would you do it??? :smile:
(What I mean is if you have to greases the gears on the inside of the case)
Please post the model numbers for your unit, so I can tell which peerless tranny you have. I have a feeling your should use Bentinite grease, but want to double check.
Ok i will tonight when i get home
Thanks Kodie :thumbsup:
Model # H700-039
(there was another number but it was to scrached up for me to see)
but if you could would you tell me how to get the some inside off it as i plan to do it this winter
Thanks Kodie
thanks alot for your help i will have to read up though that link an get to it here in a couple of weeks :thumbsup::thumbsup::smile:
