Walbro LMT-34 needle
Philip Price
Greetings. Could anyone please provide the fuel input NEEDLE part number for a Walbro LMT34 which is sometimes called LMT-54993 or 799727.
Require to order an OEM part, you help would be so appreciated, Thank you,
Phil
What is the model and type of the briggs engine. The carb parts are ordered by model number of the engine. In some cases the carb numbers are used as a reference only when looking up the briggs part number
As said as the model and type numbers will help a lot.
Besides 799727 refers to a Nikki not a Walbro. But the LMT carburetors appears to use 231855S.
Phil
Thank you for a brilliant reply. The Briggs engine is 28Q777-0016-01 Code 9310284a. Please can you confirm 231855S is correct. It has a rubber ? cap on the pointed end of the needle. Ones I have received have been incorrect. I am 86 years old and your help is incredibly appreciated. Philip Price
