volt meter gauge
reynoldston
A wheel horse 314-8 has a volt meter and a hour meter. That is the way they have it wired so why in the world would you want to change it to a amp meter? Just put 12 volts across it and it will read 12 volts. If not you need a new meter. Keep your wiring the way the tractor was made or you can end up with a big mess if you don't know that you are doing.
I agree with reynolston on this one. Your only asking for trouble if you try to install an AMP meter.
