volvofan94
- Apr 18, 2023
- 7
- 37
I’ve set the mixture screw 2 turns out from the fully closed (tightened) position. I’ve tried a variety of settings for the mixture screw, but none have worked to date. The tip of the mixture screw is in good condition. Looks like the manual says 1 1/2 turns for initial. Will try that then post back.
My carb doesn’t have the idle speed screw mentioned in step 4 of the Final Adjustment procedure. May have gone missing over the years. Will replace it.
