Victa V40 rebuild
acecleaning
Hey all,
I picked up a Victa lawnkeeper v40 (OHV 4stroke) from somewhere awhile ago. It started but had a knock to it. I opened case and piston rod arm bolts were nearly falling out so i tightened up, checked timimg, all seemed fine and turns easily. Re-placed case. checked for compression, check spark, fuel air.
Now it wont start, at all. Ideas???
Thanks
chance123
Check for your normal things like spark, fuel, and compression in that order
