I have a Partner P12597. I guess it is the same as a Poulon in the US.
Nevermind the brand of the mower, the rearaxle is a 6 speed Tecumseh/Peerless product.
More precise:
Tecumseh / Peerless
8035B – 0343
model spec
H MST – 205 – 544C
The thing shfts OK between neutral and first gear; and between neutral and reverse.
So that's what I use now so I can cut the grass.
But it is very difficult to shift to second or higher gears and even harder to shift back!
What I found out is that there is a mistake in the norwegian manual. There is writen that it is OK to shift up and down without using the clutch and even under load!
That is wrong. But it could be the reason of my trouble now.
I'm afraid that I have to open the tranny/axle to find out what's wrong........but......time is a problem.
So I found a axle for sale which is from a Viking Cyclon. Type of this as is: MST-205-535F
Is this axle useable for this mower? Somebody who is familiar with the MST code?
Tips what could be wrong with my own axle are welcome too of course!
More precise:
Tecumseh / Peerless
8035B – 0343
model spec
H MST – 205 – 544C
