Compression reading?
Test it this way. Use no oil or any lube just dry with only the oil left over from the last time it was run. Note reading on the first pull, then pull 3 more times note this reading , then pull until needle stops rising and note the last reading. I should have asked this first, What is the model and serial numbers?
The compression reading at the time of assembly prior to being run may be a false reading. Only after running and washing out the assembly lube and testing on a cold motor will you get a true reading. The actual reading after having run the motor may be border line and is lower than 70lbs. If you have been using starting fluid to get it running you may have washed the oil off of the rings and lowered your compression below the minimum 65lbs required to run. And then by adding fuel / oil mix you then relubed the rings and cyl walls restoring the compression high enough to run. Wait until tomorrow with a cold motor and retest the compression. What is your spark plug gap and spark plug number and brand?
Photo, Glad your'e running. Two stroke did mention an important topic-crankcase pressure. Maybe he will say more for 2 strokers watching, like the test gear used to test crankcase pressure.
Two stroke. Weak sparks get weaker at hot as the transistors miss there and improve a little at cold. But they cannot heal themselves like a semi-gummed carb. :smile:
I have new crankcase seals
I have new gasket between reedplate and crankcase
I have new reeds, adjusted correctly
I have new gaskets for top and bottom plates.
I have new gasket between cylinder and crankcase
