Very frustrated- is Snapper dealer not truthful?
Ilmbg
Hi, I just found your forum. I am extremely frustrated/mad/ whatever.....
1. I April last year I bought a new Snapper 33", 15.5h rear rider. I do not know the model- I can't even find it in the manual...!
2. In July of last year, after using the machine a few times on 5,000sq ft, I thought it was too noisy and vibrating badly. This is flat/NOT thick grass in central Florida. No slopes. No hills. No rocks. Nothing except grass.
3. I called the dealer I bought the mower from and the guy who came out to pick it up said it was definitely too rough and said he thought maybe the blade or shaft may not be straight. There were not enough hours for an oil change but because the mower was going to be there I had the first oil change done at that time. Maybe 5 hours.
4. The dealer called back and said, "there is absolutely nothing wrong". You owe me $250. Brought mower back.
I have not used the mower except on a VERY limited basis due to history of severe back/neck injury. Maybe 2-3 hours on it since then. I still felt it was too 'vibrating' and noisy, but this is my first small mower. I have been having someone do the front yard. There is no backyard yet.
5. Today, my neighbors brand new Husquavarna (1 week old) would not start, so he used mine. He also has flat ground but much thicker grass. No rocks, slopes, etc. my mower did not do well in the thicker grass. It bogged down, seemed to get hot/smell. He said it was overall very noisy and vibrated WAYYYYYY too much. He stopped using it in the front yard and did his back yard. My machine did not cut so great so he went over it a second time. Grass is thinner in his back yard. The grass in both front/back was cut last weekend. He did not attempt to finish the front yard because he thinks (is certain) something is wrong. He suspects a crooked blade or shaft-as did the guy who picked it up when I first noticed the problem.
6. Why would a dealer say "nothing is wrong", when it is/was obvious there is a problem? Neighbor thinks it may be because he is the dealer/seller and does not want to do the work?? It obviously was under warranty- it was about 2-3 months old when I told him of the problem, and the 'pick-up guy' verified it.
Is it because I am single female and just decided he didn't feel like correcting the machine and I wouldn't know the difference?
I do not dare even use the machine at all now..... I am concerned that whatever is wrong has gotten worse and now the repair costs will be outrageous. And it should have been fixed at the time I had the dealer look at it.
I actually have a video that I recorded in August-right after I got the machine back. I think it is too long for me to download to here. I sent it to the dealer in August, but no reply.
I will call Snapper Monday and describe the problem.
Do any of you have any suggestions on how to get this taken care of??
I am the only person responsible to get this taken care of and have been screwed over in the past- guess 'she's just a stupid female', attitude of dealer?? Because I am disabled and am not able to mow much maybe he figures I won't know there is something wrong??
Sorry about the lengthy post but I wanted to be clear.
I think I need some help....
If you have hard copies of the service history ( the video will usually do ) take your problem to your consummer advocate.
Treating women like mechanical idiots is very common down here as well and gets my other half really pissed.
She has fully rebuilt about a dozen or more veteran motorcycles including all of the machining and even worse,,,, did them all better than mine.
When she goes to the car dealer she gets talked to like she would not know which end of a screwdriver you hold and has the IQ of a peanut.
She then goes directly to the Womens Advocate ( we have a state & federal one down here ) and lodges a complaint.
Apart for a master machinist class 1 diploma she has 3 degrees and 8 post graduate diplomas being an archioligist & conservator.
When she returns, no one talks to her apart from the manager,,,, very politely and when she passes over her business card thay just about feint.
So this is how I would handle it. Take a glass with you. Have them start an exact mower and engage the blade and set the glass full of water on the mower and see how much spills. Then do the same thing with yours. If the same then nothing is wrong if different then they have some explaining to do.
I would say he's not being Truthful. It sounds like he just doesn't want to deal with the problem or situation or is trying to find away to void the warranty. (Be careful) I'd find another dealer and get an opinion from them as to what the problem is. You could have blade replaced and see if that helps. If it is out of balance or bent it can cause a vibration problem. I wouldn't use the mower the way it is because what ever is causing the vibration problem if not fixed could get worse and probably cause other problems.
I would start by contacting Snapper, explaining the problem, then asking them for a dealer to help you solve. Don't mention the original dealer unless prompted. If they recommend the same dealer, explain why you will not go back there. You might even ask for an authorized servicing dealer at the very beginning. If the dealer has had complaints before, this will put another. Black mark behind their name. We have two dealers in our area which sell and have poor service, and I know that one of them may be loosing the brand because of service like you explain.
It sounds like you have a bad spot on the belt. Every time that spot hits a pulley (3 times per revolution) it will loosen/tighten a bit. The worse the defect, the worse the vibration. If you can't see it, you need to take it off the mower and run it between your fingers. You will feel a narrowed place where it was burned by a pulley, usually when the blade is stopped abruptly. Also, a loose belt will tend to burn a bit, but not usually in one spot. While the belt is off, check the pulleys for debris. It's not uncommon for a piece of a stick or something to get in there and cause the same issue that a burnt belt would cause. If it's either of these scenarios it would not be a warrantable repair. Regarding the $250...I think you got screwed.
I don't think it is a bent shaft or blade. Hardly any of the shaft is exposed and they almost never bend. A blade weighs the same whether it is bent or straight, so unless it is bent severely, I don't think that's the issue. HTH
