Ventilated Block Blues
bartles
Working on a 2020 Murray 30" with a 10.5 HP B&S. The block has a hole in it courtesy of the rod and associated trashed crankshaft.
Engine: 21R707 -146-G1, Code 190925ZD
Haven't priced out the part yet but, basically, should I look for a "will fit" engine, search EBAY, or .....?
Suggestions appreciated in advance,
bartles
I hate to say this but installing a new engine in a Murray is a waste of money. New engine will cost more than the unit is worth. Just speaking from experience.
ChrisBFRPKY
Hey Bartles. There are literally tons of used B&S flathead verticals still out there just waiting for a fresh start on a late model rider. If you have the usual 1"x3" shaft on yours it's likely a direct swap with the OHV. It's hard to beat an old 11 or 12HP Briggs flathead vertical. They can wear out lawn tractor drivetrains and mowing decks long before the engines ever give up. I've found they're also great replacements on things that came with the single cylinder Kohler Courage engines as long as the shaft matches.
bartles
Yep, may be "recycle" time for this little toy!
bartles
I'm thinking that is the most practical way to deal with this. New parts is certainly not a viable option.
Thanks for your input.
bartles
Scrubcadet10
Moderator
Staff member
check Small Engine Wharehouse, go to their "repower old equipment" page.
