Vanguard question
hugginjugs
I'm searching for info on a Generac V twin from an RV generator. It was propane powered. I read elsewhere that this is basically a vanguard. Can anyone confirm if this is true? I'm wanting to convert to gasoline.
Thank you.
Look at one of the valve covers and you’ll find the model, type and code numbers. With them we will be able to tell you what engine you have.
hlw49
No that is a Generac engine. it will have a sticker somewhere on the left side of the engine standing behind it.
VRR.DYNDNS>BIZ
Thank you.
to convert to gasoline is a mistake in my opinion.
