Valves move up and down together, in unison, is this right? Video attached
Well there you go.
The only lobe failures that have come into this workshop the lobe stripped thus did not turn with camshaft at all & I have only seen 2 of them
The most usual failure is a couple of the teeth break out due to hitting a rock of a big back fire, although no one ever admits to hitting rock.
A few have come in after a service trying to claim a service warrantee repair. Thus the suspicion to claim that it just happened all by itself.
Thanks for the advice. As for the suspicion, I could understand if it hit a rock but that's not the case since it's a pressure washer, not a lawn mower.
You will want to look at the pump too. Make sure its ok.
