Valve problem
claude 955
I think I have a valve problem on my model 1620 cub cadet. It is a twin cylinder kohler engine . I would like to know how much of a job is it to do a valve job on it. I must have a burnt valve on right side. If you can let me know, I would appreciate it.
Thanks
claude raybuck
BlazNT
Need to know what engine you have to give that kind of advice. Model number of the engine?
A fairly easy job.
Book time is 2 chargable hours.
Job done engine in mower.
You do need a low reading tension wrench to do it properly 0-50ft lbs a standard car one is not up to scratch.
Pull the head before you buy any parts as if you have cooked the head it will need to be replaced.
