No Jim,
We are not the CIA or FBI so no such things as too much information for your own good.
Sometimes I think this is the dentist forum because getting information is rather like pulling teeth.
So first problem solved
http://www.mymowerparts.com/pdf/Kawasaki-Service-and-Repair-Manuals/
Third manual down is yours so you now have a manual.
Yes running without the blower housing for more than 10 minutes or so will overheat the head and soften it so don't do it again.
Once softened it is effectively useless
If you had a backfire then a run on you will most likely have sheared the timing key in the flywheel so now the timing will be off and the engine will not start.
The cut off solenoid is spring loaded and rarely give any trouble unless the float bowl get full of water or gummy evaporated fuel.
IF it has 1 wire then it needs the body to be grounded to work and should retract when the ignition is turned on
Kawasaki sell valve guides #49002-2107 so the manual should have descriptions on installing them ( note I have not checked this ) or at least dimensions.
As for weather the USA & Japanese heads are different, no idea, I go to my first Kawasaki service school next month.
To check things more closely we need the spec number off the side of the engine.
Should be S?? ( ?=01 to 29 )
There is only 1 manual listed for the engine on both the USA & Aust web sites and we get both USA engines, installed in mowers & Japanese engines ( in boxes )
When you assemble the head again, put about 1mm thick plasticine across the top of the piston then turn the engine over a few times with the starter, remove the head and check for valve marks in the plasticine
