sgkent
Am in the process of doing a lite overhaul on a Briggs Engine, a 190cc L-Head. That will include cleaning the combustion area and checking valve lash. The Briggs book goes into using Led-Plate #93963 on the stems if I take the valves out, which is probably occasionally available on Ebay but most places show it as discontinued since it has lead powder in it. Is there any reason I cannot just use the red Assembly lube (Ultra Slick) on it? I have some moly paste that I can mix with it if critical, although moly is a two edged sword. When the molecules are flat, it is really slippery, but when the molecules stand up on end, it is an abrasive. I've always just used engine oil on valve guides but generally try to follow factory procedures.
Led-Plate
Ultra Slick
Led-Plate
Ultra Slick
