Agreed.The downside is because it is a PIA job to clean the silicon off
Yep, On the Honda GCV or GC engines with the Hondabond plan on replacing the valve cover because it will get destroyed in the removal process.Agreed.
And the silly-cone glues the cover TO the block making it a bear to remove. You will bend up the valve cover nicely going after some lazy fool that used silly-cone. I've seen several Honda pushers that were glued on (silicone). They would not budge at all. Couldn't get a putty knife behind the cover. Mower ran so I informed the owner.
Just use the OEM gaskets with some hi-tack spray on them. Little Indian Head or hi tack spray.
I only use Indian head gasket shellac on equipment of people I don't like. Put it on both sides of a paper gasket and enjoy. Right up there with Permatex #2.Just use the OEM gaskets with some hi-tack spray on them. Little Indian Head or hi tack spray.
