Valve clearance query
topconker
So, the debacle continues!
About to remove the valves on my K141 and have noticed there is a large gap already on the valve clearance even before I lap the valves in. There is no adjustment on this motor, so not quite sureof the way forwards.
Would I be right in thinking when I lap the valves in, because they definitely need it as they suffer from blow through, will the gap decrease?
It should down load, check you download folder. I’ll stay here for an answer, and if it doesn’t work I’ll send it another way.
Have downloaded the file but still can't open it so must be a problrem my end, I'll have a look as to why I can't open it.
Does it explain how to lap etc?
If you can get it and I’ll go to another website, be back later better half is sending me on a service call.
