valve adjustment
Dave J
Do I loosen the nut that holds the push rod guide plate ?
What engine are you adjusting the valves on. If Briggs, there should be a nut on top of the rocker, with either a torx set screw in the center or if Vanguard a double nut to lock the adjustment setting.
