Do I loosen the nut that holds the push rod guide plate ?
D Dave J Forum Newbie Joined Apr 10, 2013 Threads 1 Messages 2 Apr 10, 2013 / valve adjustment #1 Do I loosen the nut that holds the push rod guide plate ?
I ILENGINE Lawn Royalty Joined May 6, 2010 Threads 43 Messages 10,733 Apr 11, 2013 / valve adjustment #2 What engine are you adjusting the valves on. If Briggs, there should be a nut on top of the rocker, with either a torx set screw in the center or if Vanguard a double nut to lock the adjustment setting.
D Dave J Forum Newbie Joined Apr 10, 2013 Threads 1 Messages 2 Apr 11, 2013 / valve adjustment #3 kohler sv 600
R Rivets Lawn Royalty Joined Mar 11, 2012 Threads 59 Messages 15,307 Apr 11, 2013 / valve adjustment #4 This manual should help you. http://www.mymowerparts.com/pdf/Koh...urage-SV470-SV480-SV530-SV540-SV590-SV600.pdf
