- May 6, 2010
- 11,983
Have worked on a generator that has 5% bypass when tested with a leakdown gauge, but compression gauge showed 5 psi. Have come across several out of the box Briggs push mower engines that had 30 psi before even being ran for the first time and that was the old L head engines.. So compression can be misleading in some cases.Looks like a Briggs 500E. Even with compression release, 30 psi of compression is too low to start and run.
