Can you tell if the valve guides are in the block correctly without pulling the head? I just bought a used 25 V-Twin engine that had to badly bent push rods (2) in which I replaced. After reading some, I read that overheating can cause the valve guides to move in the head. I didn't pull the head, only the bottom end and cleaned the crankcase and put it back together. I replaced 2 push rods and adjusted the valves. It seems to run fine but after reading about overheating it made me think before I go further. When I removed the top plastic covers it looked like either mice had a home or somehow was swamped with grass clippings, worst than I have ever seen on anything. That what makes me believe it may have over heated at some point. The valves were free to push open by hand but in my way of thinking if the guide moved toward the spring it would cause extra pressure causing the push rod to bend. I did start it and it seems to run fine but only ran it for maybe a few minutes. Your thoughts???? In reading this to myself I don't think the spring tension would change unless the valve spring cap bottoms on the guide. Again any ones thoughts???
