BWH
- Mar 22, 2011
- 352
I am rebuilding a 1991 Briggs and Stratton 14 hp horizontal shaft v-twin model # 294447 on a 614 Grasshopper mower. When I purchased it one cylinder was dead, and it was spitting oil out the crankcase ventilation tube which was no longer returning to the air breather but just venting out the side. There was no smoke or oil coming out of the muffler and when I removed the muffler no oil residue was noted in the #1 cylinder exhaust side. After I tore it down I found an exhaust valve on the #1 cylinder head stuck open due to the valve guide sliding out of the head holding the valve open allowing compression to travel down the valve stem journal. I would try to reset the valve guide but I have been told this was an issue with these engines and resetting them even pinging them usually ends in it popping out again, has anyone had luck resetting these valve guides?
My question to the group is interchangeability of cylinder heads, I know that during the time frame of these engines the 12, 14 & 16 hp engines were the same block with the same bore and stroke with carburation being the only difference in the HP. I am wondering if the cylinder heads are interchangeable. I have a good set of cylinder heads off an 18 hp Briggs and Stratten V Twin the same vintage (slightly larger bore), unfortunately it was blown up so I salvaged everything I could but did not save the engine nameplate. I have set them on my block, and the bolt pattern bolts up perfectly. The head gaskets are identical with the exception of the cylinder bore the 18 hp gaskets are 2.90" bore vs 2.72" bore for the 14 hp. I'm not sure which head gasket set to use.
I would appreciate any information or experience on this matter. Thanks
