V belt number.
Thank you all for your input. The drawings that Star tec (appropriate name) posted had the v belt length and I went to my local supplier who confirmed that it is a 9.7mm x 8mm x 937mm long belt. Just have to wait for it to arrive as not a stock item. Hopefully up and running next week.
Just waiting for the next problem now!
Back again. My engine type is 0231-E2, so is that the 970mm belt Star Tech? Is that the outer diameter?
It is the OC and no according to the IPL it is the 940mm belt. As the 970mm appears to be only used on the 0225 type number engine.
