I'm trying to fix up this UT20818 Homelite Zip Start String Trimmer for someone. I cleaned up the carburetor (had some gunk in the screen filter), put in a new spark plug (owner didn't know where the spark plug was) and tried to start it up. I wasn't getting any spark though (It has a good 120psi compression). I wanted to get at the ignition coil and see if anything was out of place, but I can't seem to get the red cover off.
When I disconnected the trimmer shaft, there's a covering (drum?) on the drive shaft shown in this picutre
So the covering is held on with a T20 screw. Got the cover off and there's this piece on it (clutch?).
Anyone have any experience with this? how do I get this off? Looks like it can thread off, but also looks like a pain to hold the shaft from turning without damaging. Probably a good time to get a good bench vice installed.
Also now that I'm writing this thread, I should also check to make sure it's not just a problem with the wires/stop switch before I mess with the ignition coil.
Thanks,
-Marco
Thanks,
-Marco
