bluemoon11
- Apr 17, 2015
- 2
- 6
I have a Briggs (123K02 0243 E1, Troy Bilt trash day find lawn mower, 2003). I have a OTC 5609 Leak Down Detector. I'm getting 16% leak down with most in not all air coming out the oil fill tube. The compression was about 50 - 55 psi. The carb needs to be rebuilt. I got the engine running for a while and it seemed unpowered. So, is 16% OK for a 12 year Briggs? For a car engine, 16% is bad. I've never used a Briggs leak down tester. On YTube, it seems you get green or red, no percentage when using the Briggs tester. Any comments?
