Use String Trimmer underwater for cattails
Bernie40
Does anyone have any experience immersing a string trimmer with a cutter blade for underwater vegetation ? Gas powered of course, motor above water. Maybe a bent shaft model might be best.
Bernie40
This is made for it:
For $700 I could pay someone to do it!! Hasn't anyone ever dunked their trimmer?:smile:
possum
I remember those big powerful Weedy Weedwhacker ones would work under water. Guys used them to clear sapling sized stuff from around farmpond edges and tailwater pits. I have seen a couple guys trying to run a canoe with a Weedeater string trimmer. Was not working real good.
jross
It doesn't matter matter about what shaft, but what is on the cutting end. The best blades were Machete blades which was a steel disc with chainsaw teeth riveted on the circumference. They are very hard to get these days. Beaver blades are a steel disc which is grooved around the circumference on which a length of chain saw is attached. Both can be resharpened. Beaver blades were still available through Northern Tool for about $48. I suppose you could use the so called "brush blade" found in the box stores, but they crack easily. I had a tough time mowing them with my Farmall Cub with brush hog on the back, but the Cub is only a 15 HP cultivating tractor.
Bernie40
It doesn't matter matter about what shaft, but what is on the cutting end. .
Hey jross, thanks for the tips. I thought the curved shaft might be better because there are fewer moving parts at the "wet end", but yer right, it probably does not matter.
I fought the cattails for a couple hours again yesterday trying to pull them out. The smaller ones are pullable but almost sunk my jon boat when I submerged the back end pulling on a big cattail. Now if I could figure out a way to attach them to my tractor.....
