Upgrade alternator on Kaw FR691V?
metcfr00
Hey guys,
I have an Ariens IKO00N X mower with a FR691V engine. I understand that the alternator output is only 3.6A. Is it possible to upgrade it to 20-25A by installing an alternator from another Kaw engine.
Please assist/advise.....
Thanks.....
metcfr00
La Grange Texas
You will most likely need to upgrade the recti frier as well so take that off the donor engine as well.
metcfr00
I'm not sure this is really feasible from a financial point of view......I'll see if I can locate a likely used candidate donor and if it looks like it might work, I may try it.....
Thanks for all your inputs.....
Rgds from central Texas Hill Country......
John R
What are you running on the mower that needs 25 Amps?
