xp14629
- Feb 4, 2012
- 0
- 73
Any smoke from the exhaust? I have heard objectors go bad and they can sound like there is a bb in them beating back and forth, but normally they will over fuel slightly causing a black, gray, or white smoke. With it making the noise you could loosen the high pressure line to the injector till it is leaking and see what that does for the noise and for the engine rpm. Then tighten that line and move to the next one. If the noise goes away or the engine dosent change rpm any or as much as the other two cylinders, that is the one with the problem. Just keep your skin AWAY from where it is spraying out the fuel!!
