Unknown tube on H70 7HP
Scrubcadet10
Moderator
Staff member
No Sir.
I'd say that tube is the least of your worries now.
Hammermechanicman
I have fixed a bunch of those old tecumseh blocks when they blow a rod. I use an aluminum arc welding rod. If you can find a con rod i would fix it and check the govenor. Those old tecumseh engines run forever unless it runs a little too fast.
Bassman619
I found a rebuild kit with gaskets, rod and rings for $80. I’ll be $115 into it if I get that. We were thinking about just JB Welding it
tom3
I've seen JB Weld on a diesel engine in a semi truck, held up for another million miles I suppose. if the bore and bushings are still true it should work.
Scrubcadet10
Moderator
Staff member
What's the crank journal look like?
Hammermechanicman
Willing to bet the crank is fine. All the ones i have seen with blown rods didn't damage the crank unless it was run without oil.
Bassman619
Would you know where I could get that cheap? They want $6 for it at JD. Or can it be cleaned?
