CubCadetRookie
- Aug 15, 2021
- 1
New 46" Cub Cadet (purchased n May). It hasn't cut evenly since day one. I've leveled the deck (it was over 2" off when delivered) adjusted tire pressure (came with double recommended pressure in three tires), and replaced the factory blades with heavier commercial blades (verified right side up). The left side mows flat and even, while the right has always been uneven, and leaving some pieces uncut. I clean the top and bottom of the deck after each use, and have removed the pulley guards to make sure nothing is hiding.
What am I missing?
What am I missing?
