uneven cut
PerryVG
Have a Conquest 3 blade, seems like the center blade is either High (i doubt) or not turning properly as it leaves the grass in the center just a bit higher. Any help will be much appreciated. Blades are quite new and sharp.
Belt slipping. Idler pullies need replacing. Spindle needs new bearings. 3 things to check. Let us know what you find.
