Black Bart, I totally agree with everything you said, The deck is ignored, I check with the JD deck leveler from both tips of each blade and it will be perfect. After a few cuts I notice unven cuts. What am I doing wrong? Took it to the local JD dealer and it was worse when I got it back. I love my JD except for the uneven cuts. As I stated earlier my old murray hardly ever needed to be leveled, but now It seems I need to level before each cut and I usually cut about every 3-4 days.
