Twisted drive belt on Troy-Bilt Bronco
wingnut1955
I had a craftsman mower that had a bad ideler pulley it was going bad on top where I could not see it it was also plastic sears finaly gave a metal replacement pulley ran fine since. check your idler pulleys they are not expensive to replace check your belt guides and make sure everything lines up. look on you tube or google there might be a video showing what to look for
