Turning Radius
RangerJ
2019 Troy Bilt 19 horse tractor turns good to the right but barely turns to the left, Anyone have any ideas to make it better?
There is a bush at the bottom of the steering shaft which goes oval if you do not keep it lubricated.
As it is almost impossible to get to no one but the most fastidious techs ever lube it
Because the rack gear is curved turning the wheel one way pulls the gears together while the other direction pushes them apart .
Also the screw holding the shaft in place is a #4 Phillip and is Loctited in place. You need a high torque (impact) rated bit to remove the screw.
RangerJ
Thanks for the advice, I know where to start now.
