model number 13wn77ks011
So out mowing, pull the blades handle up and put it in reverse and it starts trying to cut out. I knew something was wrong, put down the blades lever again blades activated, then pulled it up to turn it off again so i could reverse. Same thing happened again. So i shut the mower off... and now it won't start. What went wrong here.... also I'm getting nothing from turning the key. Battery has juice. thanks.
