Not 4 wheel steer ...
The wheel on inside of the turning circle is actually turned a bit sharper than the outside wheel, it actually 'looks' like it is almost 90 degrees out from the direction of travel...
Have not seen these on actual turf But it seems like it would almost plow through a turn that tight... :smile:KennyV
#3
wjjones
How are these different from the older 18" turning radius steering systems?
