Turf Tiger Cat Diesel
Dwellonroof
New here, I'm Martin from east of Cincinnati and am a new used Scag TT owner she's a Cat diesel 28 hp with around 340 hours and a 2015 model year I'm thinking.
That being said I noticed a slight oil leak at either a bolt or plug which I'm afraid to remove not knowing if it connects to the camshaft or something else inside.
If anyone here can help I would be grateful.
Update:
Went ahead and decided to see if I could fix the leak without taking anything else apart and found that it was only a plug with an O ring so I replaced the O ring and put a little axle grease on it before I installed it.
No Leaks!!!
7A9238F4-BDCA-4DCE-92D3-7883C4857F7B.jpgF40DC1CB-A8DE-4CB1-AE37-D391DFC6171B.jpgF3071E7D-28C3-428D-9C45-D8323F2E57DB.jpg
BTW I really like the Turf Tuger Diesel even though it weighs more than a gasser , it powers through the same wet spots as the old kohler powered one that I had a few years ago.
It will get stuck in the same spots also.
Welcome to the forum and congratulations on the Tiger Cat. Those are pretty serious machines. Sorry nobody replied to your question but glad you got it resolved.
