jakesmurray
- Jun 13, 2011
- 65
- 352
I have a 1985 8 HP Briggs and Stratton that I need to tune. It runs, but it never really finds a set RPM level. It also puffs a little bit of white smoke while it is running. Also, while I am drifing around on the mower, it bogs down and does not idle up like it should. I have attached pictures of the adjustment screws. There is one on the top, one on the bowl, and a little adjustment screw on the throttle butterfly. I also noticed that the fuel line from the tank to the carb is lopping down. Will a good fuel supply get to the carb if it is like this? I have taken a picture of that as well. I jut need to know the procedure for adjusting the screws to get it to run properly. Thanks
