Engine Tuner mods
Lillite
Hey All,
I’ve got a Freedom Z that I bought about 13 years ago. Been running pretty well except that I burned the engine up and had it rebuilt last year (cooling fins clogged with dust).
I’d like to get more power out of the Kawasaki engine and higher tip speed on the blades. Are there any tune ups available for that engine?
Max RPM is set at the factory, any more than that will ruin the engine.
Go to a local shop and see if they can tach it out and see what rpms it is turning if they don't have a tiny tach you can order and tach it out at 3600rpm
