ARMYtango
Hey all...
Loving the info on this forum! But am having a hard time locating any info on the issue I am having.
My neighbor asked me to look into getting an old mower that he had sitting around to see if I can get it going.
After some work, I have gotten it running, and even gotten the drive to work. Only problem I have now is when you release the drive, the front wheels will not roll freely.
I have opened the drive box and can verify that the gear IS releasing like it should, so I know that is not the problem.
After taking off the wheels, I have found that I can turn the gears if I use a wrench, or if I put some muscle into it with my hand. So I am wondering if there is a way to possibly grease the axle in some way?
Like I said before, the drive works perfect, so I know the axle/gears are not bound up.
Thanks all in advance! :thumbsup:
