Troybilt Pony 2006
thoward6471
The suspension on the front is not working correctly. The right side stays up and will not go down on the front but when I jack it up and move the I beam it will go all the way up. I cannot figure out what is going on. Any suggestions? Thanks,
mechanic mark
http://www.troybilt.com/equipment/t...By=&pageSize=12&page=5#cm_HEADER_OWNER_CENTER
Make sure this is your model number. Safety First, scotch back wheels with brake on. Jack up front end, use jack stands if you have them, & inspect front end parts for excessive wear, drag link, ball joints, bushings, etc. using a pry bar, a helper would be beneficial. Do not put yourself in Danger under tractor. Pulling front wheels & using jack stands would be to your advantage. Let us know how it goes.
Try using a spray can each of penetrating & lubricating oil & let it soak a while after each use to loosen things up, this goes for all moving parts.
thoward6471
This was a hand me down but runs good after some work. There is some wear in the spindles and ball joints but not bad. Nothing like the mtd I have. If I can get the chassis to level out I believe it will be a good running mower. The pivot bar was froze when I first got it but it now will go up and down when I move it by hand. I can push it all the way up but when I let the jack down it will raise back up. Could the chassis be bent? I haven't seen any bends in it.
