Troy built mowers, don't want the oil changed, just add to original oil ??
KM Richards
  • / Troy built mowers, don't want the oil changed, just add to original oil ??
they no longer put a drain pug in the oil pan
That's easy... just drill a hole, tap some threads and put a plug in!
You'll get more of the old oil out when draining it from a hole in the bottom when the engine is hot so this is beneficial over sucking out out from the top.
