Troy Built 2010 bronco riding mower Problem with speed pedal not disengaging.
Curtisun
  • / Troy Built 2010 bronco riding mower Problem with speed pedal not disengaging.
I have a 2010 Bronco model 13WX78KS066.
What has been done since it came in.
1. Lower and upper drive belts replaced.
2. Deck belt, Spindles and blades replaced.
3 Ignition switch replaced.
The problem is when you place it in gear Foward or reverse it goes in low speed and will speed up when speed control pedal is pressed and will not stop it until you put it in neutral. I have found no adjustments for the tension on the lower drive belt which controls the speed. It works sometimes if you mess with pressing brake and speed pedals but it always goes back to not working. Does anyone know what to do about it or had this problem?
First question? Did you use OEM belts when you replaced them. If not that is a most likely the cause of your issue. Second question is the return spring connected so that it brings the go pedal back to the neutral position.
Curtisun
This was supposed to be a OEM belt. But bought on Amazon. It measured out correct to the specs because I thought the same thing after I got it in. The go pedal has only the return spring going to the pedal that returns the pedal to it's up position. This pedal has turtle and rabbit marked on it. The belt should slip with the pedal up. It has no spring on the belt tensioner. This sort of floats when the speed pedal is up.
be below is a parts breakdown. The circled blue is the variable speed and upper belt tensioner spring. The circled red is the lower belt tensioner that has no spring.
Curtisun
The slotted arm in part 69 and rod 56 that attaches to the brake pedal does not make contact with either end of the slot with the pedal up or down, so it does not force it to neutral when you press the brake. It seems there is something not right in that area. The Speed pedal does force contact and move part 69 to speed it up but does not contact the other end when the pedal is up.
Also is that variable speed pully supposed to be spring loaded or is it supposed to be just one side free floating because when I put the belt on I had to raise the one side with my finger and it had no spring loaded pully.
The center section of the variable pulley is free floating. Also it looks like item 55 which is the idler tension arm may have a threaded end with a ball joint and lock nut at the pulley end. Is it possible that this has had incorrect belts installed in the past and somebody has adjusted that rod to compensate for incorrect belts.
It wouldn't be the first time someone Amazon claimed the belts are MTD when they are not.
Belt specs
954-04208A 2/3 x 40-9/10-in
954-0467A 2/3 x 90-4/5-in
Many places will try to pass off a 5/8 (.625) belt in place of the .656 belt plus those 5/8 have a different height profile which sits deeper in the pulleys causing the belt grab the v quicker. If you work on enough MTD CVT drives you will quickly learn that only MTD OEM belts works; all others will give various problems.
From the top
What was it doing before you changed the belts ?
Next what did you undo / remove & replace in order to replace the belts ?
does the plate # 69 move freely back & forward with nothing connected to it ?
Is spring # 38 back in the correct place "
Has spring # 38 chopped a long slot in the frame where it anchors to ?
Can the tension arm # 72 swing freely with the spring removed ?
Are both the belts wrapped ?
I have had customers come in with what they thought was the right belt only to see they had fitted a plain belt which is uncovered so becomes sticky when hot .
Curtisun
It started working on its on 😂. Not sure what change may have been just needed running some.
Curtisun
From the top
The belts were worn so bad it would not move.
It seems to be ok now. It is working properly. The belts were not OEM as stated because I do not think OEM supplies a Kevlar belt. I would not look forward to another 3 hrs. work to replace it again. Worst belt I have ever replaced. No room anywhere it goes over a pully. About 1/8 inch clearance on the centrifugal pulleys and it does not have a bolt bolting the pully on shaft like shown in the parts. I had to remove bolts out of bracket and pry the bracket back away enough to force the belt on pully. It has a shaft that is a washer is welded on the pully side and it is factory welded. It is bolted on from the bottom next to the rear axle housing could not get to it to remove would have had to pull rear end completely out. This one has been a pain.
Since it is working, and I give a warranty on anything I work on I will redo the job if I have too.
Curtisun
Belt specs
This belt measured .654 using my calipers. Length was 90 3/4 inches so it was Very close to the (954-0467A) and I agree with you about the OEM belts but when a customer says use aftermarket because of price you either lose the job or use aftermarket. I am not a full shop I do this just to earn some extra to help because I am SS and it does not provide the funds for everything. I am 72 and was forced to retire. I lost all my IRA funds in the 2009 crash so have no choice but to take in work I can get.
