rmiller24r
- Mar 3, 2014
- 1
- 2
Hello Everybody,
I have Troy Bilt zero turn riding mower I recently purchased. It is equipped with the Kohler Courage 25hp 725cc motor: Spec PS-SV730-3043 : Serial 4304504874.
The issue has been occurring when I have tried to start the mower, it will crank but will not start up. The mower will run perfectly fine if I use start up fluid, but without its use it will not start up. I thought that it could possibly be the fuel pump since it seems like a fuel delivery issue, so I replaced the fuel pump and with no success the motor still does not stay running(I thought possibly previous owner put old fuel in + it has been sitting at dealer for a while possibly = lead to clogging somewhere in the lines and pump.) I was wondering if any one could possibly point me in the right direction. Btw the mower only has 5 hours on it, so all the parts on this motor should be good, but apparently something has failed. Again it runs perfectly fine and stays running if I use engine start up fluid when I crank it up.
