rickpaulos
- Nov 2, 2012
- Threads
- 31
- 92
I bought a very used 2010 Troy Bilt tiller recently.
Cleaned the tank, replaced the broken fuel line, changed the engine oil, cleaned the spark plug, cleaned the foam part of the air filter. It popped a couple times on the first pull then just refused to start. No spark from the coil. I removed all the ignition kill wires and still no spark. Bad coil. A new coil for $15 or a full kit for $25. I got the kit: coil, carb, fuel line, fuel filter, all new wires, plug, capacitor, switch, gaskets. Installed all that (except the wrong size spark plug) and it started on the first pull. Motor runs pretty good. Honda clone by Lifan.
The tines turn but the wheels are pretty jerky or just don't go. Pulled the transmission cover off. Ugh, no lube in the transmission and brass everywhere. I partially dismantled the transmission to remove the wheel shaft drive gear and clean out the case. Need to get a replacement wheel drive gear.
In searching the www, I find the same part number for Troy Bilt, Craftsman, MTD, Cub Cadet, Yardworks, etc. All MTD products. And the same part has at least 4 part numbers which I assume are the different brand name numbers. Not a cheap part. $100 to $145 for the gear. 1.7 pounds of solid brass.
