TROY BILT THERMOSTAT
CubbyCommando
There is no power connected to the auto choke systems on either the Briggs or Honda auto choke systems. Heat from the muffler causes the wax pellet to expand. Mechanical linkage between the auto choke assembly and carb opens the choke as the wax expands, moving the linkage. Plenty of you tube videos can explain it better than I can.
Yeah, that was totally my bad on jumping in this thread with my limited knowledge. Regrets if I confused matters. Cheers.
