TROY BILT TB 280 ES WONT KEEP RUNNING
chazdo2
I have a TD 280 self propelled with the 725 Briggs EX engine. Starts right up dies within seconds. Completely cleaned the carb, gas cap vent works, new air filter , gas tank in line screen cleaned, new spark plug. Rubber gasket and plastic ring in the carb on the intake pipe are perfect seated properly. Valve clearances are in spec. Float valve and float work perfectly. Seems the problem is not enough gas but I cannot figure out why? Driving me crazy I had this same problem years ago ended up buying a new card fixed it. I hate not knowing why I have this problem.!!!! I have had this problem 3 different times over the years. Figure one of you thats brighter than I must have figured it out. PLEASE HELP!!!!!!!!
Did you clean the fuel bowl bolt? It is the main jet for the engine. This is provide this is the 128M series engine.
Try an electric fuel pump and bypass your tank run it straight from a clean fuel source and see what happens
