I got the super bronco to run, my next question is it possible to flush the transmission and add new fluid. It is a 2006 model and probably has never been changed.
Thanks. Jack
Thanks. Jack
Model is 13AX60TG766. JackPlease the actual model number from the serial number tag.
Thanks for the information. JackOkay first that mower doesn't have a hydrostatic transmission. It is CVT single speed manual transaxle system that uses grease (00 Grease). You have to dissassemble it and manually remove the grease before add new grease.
Question: Is there a method of testing the reliability of the CVT transaxle without actually hooking it up to the motor. Like spinning it with an electric drill. JackOkay first that mower doesn't have a hydrostatic transmission. It is CVT single speed manual transaxle system that uses grease (00 Grease). You have to dissassemble it and manually remove the grease before add new grease.
I took your advice and disconnected the upper drive belt, jacked up the rear end and turned the CVT with my electric drill. The right wheel turned continuously in forward and in the reverse, while the left wheel only turned once in a while. I did hear a “strange noise” coming from the transaxle. It is probably not worth fixing. Any thoughts or advice. Jack.Just enter your Model Number above.
You will need 3 tubes of grease above if you so choose to replace grease.Benalene Grease 920 8 Oz - 737-0300A | Troy-Bilt US
Read reviews and buy Benalene Grease 920 8 Oz737-0300A. Free shipping on parts orders over $45.www.troybilt.com
The answer to your question below is you will need a helper, Safety First: Scotch front wheels & place rear axle on jack stands, sitting in seat Operate tractor in forward & reverse listening for any noise, let us know how it goes, thanks, Mark
