Pulled mower out of storage today, changed the oil and went to make my first cut and it did not want to go any higher than 3rd gear. I could physically shift it into higher gear but transmission seemed to only want to go to 3rd. Did some investigating and the pedal only seems only hold tension until 3rd and than the teeth no longer come in contact with the stopper connected to the pedal.
I am very unfamiliar with mower repairs, from my brief research could potentially be a belt or pulley issue? Any kind of suggestion or insight would be greatly appreciated.
