The bearings are frozen in the blade spindle assemblies. There is a product called PB Blaster which I have found very effective on freeing up almost anything. It can be found at Autozone, Dollar General and Walmart. It comes in a spray can. Try spraying this down into the bearing area and use a breaker bar on the top nut (should be a 7/8 or 15/16 socket and move it back and forth if possible. If this doesn't work the bearings inside the housing will need to be replaced. It might be easier to replace the entire spindle assembly.
